Time Before: 0.01600 seconds
Time After: 0.02217 seconds
Time Taken: 0.00617 seconds
Time Before: 0.02226 seconds
Time After: 0.02271 seconds
Time Before: 0.02295 seconds
Time After: 0.02311 seconds
Time Before: 0.02386 seconds
Time After: 0.02659 seconds
Time Taken: 0.00273 seconds
Time Before: 0.02317 seconds
Time After: 0.03112 seconds
Time Taken: 0.00795 seconds
Time Before: 0.03964 seconds
Time After: 0.04011 seconds
Time Before: 0.04273 seconds
Time After: 0.04398 seconds
Time Before: 0.03882 seconds
Time After: 0.04418 seconds
Time Taken: 0.00536 seconds
Time Before: 0.07217 seconds
Time After: 0.07234 seconds
Time Before: 0.24005 seconds
Time After: 0.24128 seconds
Time Before: 0.25019 seconds
Time After: 0.25034 seconds
Time Before: 0.25286 seconds
Time After: 0.25433 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=13682', badlocation = 1 WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.27459 seconds
Time After: 0.27481 seconds
Memory Before: 4,911.109 KB
Memory After: 4,911.336 KB
