Time Before: 0.01474 seconds
Time After: 0.02339 seconds
Time Taken: 0.00866 seconds
Time Before: 0.02350 seconds
Time After: 0.02441 seconds
Time Taken: 0.00091 seconds
Time Before: 0.02469 seconds
Time After: 0.02495 seconds
Time Before: 0.02583 seconds
Time After: 0.02837 seconds
Time Taken: 0.00254 seconds
Time Before: 0.02500 seconds
Time After: 0.03231 seconds
Time Taken: 0.00730 seconds
Time Before: 0.04240 seconds
Time After: 0.04320 seconds
Time Taken: 0.00080 seconds
Time Before: 0.04623 seconds
Time After: 0.04777 seconds
Time Taken: 0.00154 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04133 seconds
Time After: 0.04800 seconds
Time Taken: 0.00667 seconds
Memory After: 2,261.703 KB
Time Before: 0.09002 seconds
Time After: 0.09057 seconds
Time Taken: 0.00055 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11528 seconds
Time After: 0.11657 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.12601 seconds
Time After: 0.12622 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.12875 seconds
Time After: 0.13030 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=136865' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.14948 seconds
Time After: 0.14975 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
