Time Before: 0.02291 seconds
Time After: 0.03114 seconds
Time Taken: 0.00823 seconds
Time Before: 0.03122 seconds
Time After: 0.03167 seconds
Time Before: 0.03194 seconds
Time After: 0.03217 seconds
Time Before: 0.03315 seconds
Time After: 0.03618 seconds
Time Taken: 0.00303 seconds
Time Before: 0.03226 seconds
Time After: 0.04183 seconds
Time Taken: 0.00957 seconds
Time Before: 0.05231 seconds
Time After: 0.05276 seconds
Time Before: 0.05532 seconds
Time After: 0.05655 seconds
Time Before: 0.05160 seconds
Time After: 0.05677 seconds
Time Taken: 0.00517 seconds
Time Before: 0.09669 seconds
Time After: 0.09689 seconds
Time Before: 0.11457 seconds
Time After: 0.11581 seconds
Time Before: 0.12830 seconds
Time After: 0.12846 seconds
Time Before: 0.13143 seconds
Time After: 0.13288 seconds
UPDATE session SET lastactivity = 1782957055, location = '/forums/private.php?do=newpm&explain=1&u=136899', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.15297 seconds
Time After: 0.15331 seconds
Memory Before: 4,289.344 KB
Memory After: 4,289.555 KB
