Time Before: 0.02316 seconds
Time After: 0.03222 seconds
Time Taken: 0.00906 seconds
Time Before: 0.03231 seconds
Time After: 0.03275 seconds
Time Before: 0.03301 seconds
Time After: 0.03319 seconds
Time Before: 0.03399 seconds
Time After: 0.03696 seconds
Time Taken: 0.00297 seconds
Time Before: 0.03327 seconds
Time After: 0.04145 seconds
Time Taken: 0.00818 seconds
Time Before: 0.04971 seconds
Time After: 0.05016 seconds
Time Before: 0.05277 seconds
Time After: 0.05400 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04898 seconds
Time After: 0.05419 seconds
Time Taken: 0.00521 seconds
Memory After: 2,261.703 KB
Time Before: 0.09337 seconds
Time After: 0.09357 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.11746 seconds
Time After: 0.11877 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.13225 seconds
Time After: 0.13248 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.13526 seconds
Time After: 0.13674 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=136903' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.15491 seconds
Time After: 0.15517 seconds
Memory Before: 4,287.188 KB
Memory After: 4,287.430 KB
