Time Before: 0.01110 seconds
Time After: 0.01429 seconds
Time Taken: 0.00319 seconds
Time Before: 0.01439 seconds
Time After: 0.01486 seconds
Time Before: 0.01515 seconds
Time After: 0.01529 seconds
Time Before: 0.01626 seconds
Time After: 0.01867 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01537 seconds
Time After: 0.02358 seconds
Time Taken: 0.00821 seconds
Time Before: 0.02854 seconds
Time After: 0.02904 seconds
Time Before: 0.03218 seconds
Time After: 0.03342 seconds
Time Before: 0.02759 seconds
Time After: 0.03368 seconds
Time Taken: 0.00609 seconds
Time Before: 0.05117 seconds
Time After: 0.05132 seconds
Time Before: 0.06227 seconds
Time After: 0.06369 seconds
End call of global.php: 0.066581010818481
Time Before: 0.07181 seconds
Time After: 0.07211 seconds
Time Before: 0.07491 seconds
Time After: 0.07640 seconds
SET lastactivity = 1776632695, location = '/forums/private.php?do=newpm&explain=1&u=136947'
Time Before: 0.09744 seconds
Time After: 0.09786 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.096050977706909 seconds with 9 queries, spending 0.0085461139678955 doing MySQL queries and 0.087504863739014 doing PHP things.
