Time Before: 0.00251 seconds
Time After: 0.00310 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00321 seconds
Time After: 0.00368 seconds
Time Before: 0.00402 seconds
Time After: 0.00416 seconds
Time Before: 0.00512 seconds
Time After: 0.00769 seconds
Time Taken: 0.00257 seconds
Time Before: 0.00424 seconds
Time After: 0.01213 seconds
Time Taken: 0.00790 seconds
Time Before: 0.01460 seconds
Time After: 0.01535 seconds
Time Taken: 0.00075 seconds
Time Before: 0.01832 seconds
Time After: 0.01961 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01369 seconds
Time After: 0.01986 seconds
Time Taken: 0.00617 seconds
Memory After: 2,261.703 KB
Time Before: 0.02708 seconds
Time After: 0.02721 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02966 seconds
Time After: 0.03097 seconds
Time Taken: 0.00131 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.034018039703369
Time Before: 0.03563 seconds
Time After: 0.03578 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03889 seconds
Time After: 0.04045 seconds
Time Taken: 0.00156 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=136966', badlocation = 1
Time Before: 0.05456 seconds
Time After: 0.05488 seconds
Memory Before: 4,288.281 KB
Memory After: 4,288.508 KB
Page generated in 0.053601980209351 seconds with 9 queries, spending 0.0087118148803711 doing MySQL queries and 0.044890165328979 doing PHP things.
