Time Before: 0.00147 seconds
Time After: 0.00207 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00214 seconds
Time After: 0.00247 seconds
Time Before: 0.00265 seconds
Time After: 0.00277 seconds
Time Before: 0.00344 seconds
Time After: 0.00591 seconds
Time Taken: 0.00247 seconds
Time Before: 0.00281 seconds
Time After: 0.00937 seconds
Time Taken: 0.00656 seconds
Time Before: 0.01137 seconds
Time After: 0.01182 seconds
Time Before: 0.01324 seconds
Time After: 0.01437 seconds
Time Taken: 0.00114 seconds
Time Before: 0.01076 seconds
Time After: 0.01458 seconds
Time Taken: 0.00381 seconds
Time Before: 0.01959 seconds
Time After: 0.01971 seconds
Time Before: 0.02145 seconds
Time After: 0.02263 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02540 seconds
Time After: 0.02551 seconds
Time Before: 0.02748 seconds
Time After: 0.02891 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137017' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.04107 seconds
Time After: 0.04135 seconds
