Time Before: 0.00198 seconds
Time After: 0.00254 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00265 seconds
Time After: 0.00321 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00351 seconds
Time After: 0.00364 seconds
Time Before: 0.00451 seconds
Time After: 0.00681 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00372 seconds
Time After: 0.01177 seconds
Time Taken: 0.00805 seconds
Time Before: 0.01431 seconds
Time After: 0.01469 seconds
Time Before: 0.01727 seconds
Time After: 0.01860 seconds
Time Taken: 0.00133 seconds
Time Before: 0.01355 seconds
Time After: 0.01892 seconds
Time Taken: 0.00537 seconds
Time Before: 0.02645 seconds
Time After: 0.02657 seconds
Time Before: 0.02864 seconds
Time After: 0.02999 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03324 seconds
Time After: 0.03339 seconds
Time Before: 0.03552 seconds
Time After: 0.03697 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137036' WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.05374 seconds
Time After: 0.05412 seconds
