Time Before: 0.00201 seconds
Time After: 0.00262 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00272 seconds
Time After: 0.00333 seconds
Time Before: 0.00354 seconds
Time After: 0.00373 seconds
Time Before: 0.00439 seconds
Time After: 0.00664 seconds
Time Taken: 0.00226 seconds
Time Before: 0.00378 seconds
Time After: 0.01005 seconds
Time Taken: 0.00627 seconds
Time Before: 0.01191 seconds
Time After: 0.01235 seconds
Time Before: 0.01514 seconds
Time After: 0.01635 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01129 seconds
Time After: 0.01652 seconds
Time Taken: 0.00523 seconds
Memory After: 2,261.820 KB
Time Before: 0.02182 seconds
Time After: 0.02196 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.02512 seconds
Time After: 0.02637 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
End call of global.php: 0.028010845184326
Time Before: 0.02926 seconds
Time After: 0.02943 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.03136 seconds
Time After: 0.03312 seconds
Time Taken: 0.00176 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
SET lastactivity = 1789127106, location = '/forums/private.php?do=newpm&explain=1&u=137049'
Time Before: 0.04556 seconds
Time After: 0.04584 seconds
Memory Before: 4,288.359 KB
Memory After: 4,288.586 KB
Page generated in 0.044647932052612 seconds with 9 queries, spending 0.0083198547363281 doing MySQL queries and 0.036328077316284 doing PHP things.
