Time Before: 0.00849 seconds
Time After: 0.01051 seconds
Time Taken: 0.00201 seconds
Time Before: 0.01060 seconds
Time After: 0.01108 seconds
Time Before: 0.01135 seconds
Time After: 0.01150 seconds
Time Before: 0.01237 seconds
Time After: 0.01574 seconds
Time Taken: 0.00337 seconds
Time Before: 0.01162 seconds
Time After: 0.02066 seconds
Time Taken: 0.00904 seconds
Time Before: 0.02397 seconds
Time After: 0.02442 seconds
Time Before: 0.02598 seconds
Time After: 0.02802 seconds
Time Taken: 0.00204 seconds
Time Before: 0.02324 seconds
Time After: 0.02824 seconds
Time Taken: 0.00500 seconds
Time Before: 0.04197 seconds
Time After: 0.04212 seconds
Time Before: 0.04803 seconds
Time After: 0.05033 seconds
Time Taken: 0.00230 seconds
Time Before: 0.05659 seconds
Time After: 0.05676 seconds
Time Before: 0.05913 seconds
Time After: 0.06205 seconds
Time Taken: 0.00292 seconds
UPDATE session SET lastactivity = 1783072013, location = '/forums/private.php?do=newpm&explain=1&u=137104' WHERE sessionhash = '05bc7c79f91873f78083814ccb7adf41'
Time Before: 0.07812 seconds
Time After: 0.08207 seconds
Time Taken: 0.00395 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
