Time Before: 0.03388 seconds
Time After: 0.04099 seconds
Time Taken: 0.00711 seconds
Time Before: 0.04109 seconds
Time After: 0.04153 seconds
Time Before: 0.04181 seconds
Time After: 0.04193 seconds
Time Before: 0.04269 seconds
Time After: 0.04471 seconds
Time Taken: 0.00202 seconds
Time Before: 0.04198 seconds
Time After: 0.04863 seconds
Time Taken: 0.00664 seconds
Time Before: 0.05496 seconds
Time After: 0.05546 seconds
Time Before: 0.05786 seconds
Time After: 0.05920 seconds
Time Taken: 0.00134 seconds
Time Before: 0.05409 seconds
Time After: 0.05939 seconds
Time Taken: 0.00530 seconds
Time Before: 0.10484 seconds
Time After: 0.10512 seconds
Time Before: 0.59971 seconds
Time After: 0.60126 seconds
Time Taken: 0.00155 seconds
Time Before: 0.61292 seconds
Time After: 0.61311 seconds
Time Before: 0.61588 seconds
Time After: 0.61731 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137120', badlocation = 1 WHERE sessionhash = 'e9b85940693e8ec450606894f10508c2'
Time Before: 0.63544 seconds
Time After: 0.63574 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
