Time Before: 0.00132 seconds
Time After: 0.00184 seconds
Time Before: 0.00194 seconds
Time After: 0.00237 seconds
Time Before: 0.00267 seconds
Time After: 0.00279 seconds
Time Before: 0.00342 seconds
Time After: 0.00579 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00285 seconds
Time After: 0.01149 seconds
Time Taken: 0.00864 seconds
Time Before: 0.01374 seconds
Time After: 0.01416 seconds
Time Before: 0.01731 seconds
Time After: 0.01868 seconds
Time Taken: 0.00137 seconds
Time Before: 0.01304 seconds
Time After: 0.01892 seconds
Time Taken: 0.00589 seconds
Time Before: 0.02603 seconds
Time After: 0.02621 seconds
Time Before: 0.02903 seconds
Time After: 0.03034 seconds
Time Taken: 0.00131 seconds
End call of global.php: 0.032845973968506
Time Before: 0.03421 seconds
Time After: 0.03440 seconds
Time Before: 0.03746 seconds
Time After: 0.03925 seconds
Time Taken: 0.00179 seconds
SET lastactivity = 1789053038, location = '/forums/private.php?do=newpm&explain=1&u=137179', badlocation = 1
Time Before: 0.05767 seconds
Time After: 0.05809 seconds
Page generated in 0.05671501159668 seconds with 9 queries, spending 0.0086092948913574 doing MySQL queries and 0.048105716705322 doing PHP things.
