Time Before: 0.02104 seconds
Time After: 0.03793 seconds
Time Taken: 0.01689 seconds
Time Before: 0.03806 seconds
Time After: 0.03853 seconds
Time Before: 0.03877 seconds
Time After: 0.03892 seconds
Time Before: 0.03978 seconds
Time After: 0.04271 seconds
Time Taken: 0.00293 seconds
Time Before: 0.03899 seconds
Time After: 0.04687 seconds
Time Taken: 0.00788 seconds
Time Before: 0.06216 seconds
Time After: 0.06259 seconds
Time Before: 0.06510 seconds
Time After: 0.06638 seconds
Time Before: 0.06142 seconds
Time After: 0.06659 seconds
Time Taken: 0.00517 seconds
Time Before: 0.12065 seconds
Time After: 0.12080 seconds
Time Before: 0.14266 seconds
Time After: 0.14396 seconds
Time Before: 0.15661 seconds
Time After: 0.15678 seconds
Time Before: 0.15998 seconds
Time After: 0.16145 seconds
UPDATE session SET lastactivity = 1785306148, location = '/forums/private.php?do=newpm&explain=1&u=137208' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.19021 seconds
Time After: 0.19052 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
