Time Before: 0.00141 seconds
Time After: 0.00191 seconds
Time Before: 0.00198 seconds
Time After: 0.00239 seconds
Time Before: 0.00259 seconds
Time After: 0.00274 seconds
Time Before: 0.00351 seconds
Time After: 0.00607 seconds
Time Taken: 0.00256 seconds
Time Before: 0.00279 seconds
Time After: 0.01017 seconds
Time Taken: 0.00738 seconds
Time Before: 0.01241 seconds
Time After: 0.01290 seconds
Time Before: 0.01635 seconds
Time After: 0.01761 seconds
Time Before: 0.01165 seconds
Time After: 0.01780 seconds
Time Taken: 0.00615 seconds
Time Before: 0.02304 seconds
Time After: 0.02317 seconds
Time Before: 0.02496 seconds
Time After: 0.02622 seconds
Time Before: 0.02964 seconds
Time After: 0.02979 seconds
Time Before: 0.03189 seconds
Time After: 0.03331 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137246', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04654 seconds
Time After: 0.04682 seconds
