Time Before: 0.01137 seconds
Time After: 0.01830 seconds
Time Taken: 0.00693 seconds
Time Before: 0.01837 seconds
Time After: 0.01881 seconds
Time Before: 0.01907 seconds
Time After: 0.01924 seconds
Time Before: 0.02017 seconds
Time After: 0.02279 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01932 seconds
Time After: 0.02826 seconds
Time Taken: 0.00894 seconds
Time Before: 0.03893 seconds
Time After: 0.03931 seconds
Time Before: 0.04093 seconds
Time After: 0.04218 seconds
Time Before: 0.03807 seconds
Time After: 0.04242 seconds
Time Taken: 0.00436 seconds
Time Before: 0.07001 seconds
Time After: 0.07034 seconds
Time Before: 0.09079 seconds
Time After: 0.09204 seconds
Time Before: 0.09981 seconds
Time After: 0.09998 seconds
Time Before: 0.10264 seconds
Time After: 0.10412 seconds
UPDATE session SET lastactivity = 1785332385, location = '/forums/private.php?do=newpm&explain=1&u=137247', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.12531 seconds
Time After: 0.12569 seconds
