Time Before: 0.01073 seconds
Time After: 0.01382 seconds
Time Taken: 0.00308 seconds
Time Before: 0.01392 seconds
Time After: 0.01434 seconds
Time Before: 0.01459 seconds
Time After: 0.01471 seconds
Time Before: 0.01561 seconds
Time After: 0.01823 seconds
Time Taken: 0.00262 seconds
Time Before: 0.01479 seconds
Time After: 0.02210 seconds
Time Taken: 0.00731 seconds
Time Before: 0.02586 seconds
Time After: 0.02607 seconds
Time Before: 0.02907 seconds
Time After: 0.03027 seconds
Time Before: 0.02525 seconds
Time After: 0.03046 seconds
Time Taken: 0.00521 seconds
Time Before: 0.05258 seconds
Time After: 0.05279 seconds
Time Before: 0.06008 seconds
Time After: 0.06137 seconds
End call of global.php: 0.063556909561157
Time Before: 0.06826 seconds
Time After: 0.06841 seconds
Time Before: 0.07091 seconds
Time After: 0.07236 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=137248', badlocation = 1
Time Before: 0.09004 seconds
Time After: 0.09045 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.088917016983032 seconds with 9 queries, spending 0.0080819129943848 doing MySQL queries and 0.080835103988647 doing PHP things.
