Time Before: 0.00291 seconds
Time After: 0.00430 seconds
Time Taken: 0.00138 seconds
Time Before: 0.00439 seconds
Time After: 0.00480 seconds
Time Before: 0.00549 seconds
Time After: 0.00561 seconds
Time Before: 0.00681 seconds
Time After: 0.01074 seconds
Time Taken: 0.00393 seconds
Time Before: 0.00569 seconds
Time After: 0.01460 seconds
Time Taken: 0.00892 seconds
Time Before: 0.01801 seconds
Time After: 0.01834 seconds
Time Before: 0.02103 seconds
Time After: 0.02224 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.01734 seconds
Time After: 0.02252 seconds
Time Taken: 0.00517 seconds
Memory After: 2,261.820 KB
Time Before: 0.03152 seconds
Time After: 0.03164 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.03547 seconds
Time After: 0.03669 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.04017 seconds
Time After: 0.04031 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.04295 seconds
Time After: 0.04495 seconds
Time Taken: 0.00200 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1789142908, location = '/forums/private.php?do=newpm&explain=1&u=137249' WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.05771 seconds
Time After: 0.05806 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
