Time Before: 0.02883 seconds
Time After: 0.03178 seconds
Time Taken: 0.00295 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03187 seconds
Time After: 0.03234 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03265 seconds
Time After: 0.03277 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03356 seconds
Time After: 0.03598 seconds
Time Taken: 0.00242 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03285 seconds
Time After: 0.04014 seconds
Time Taken: 0.00729 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04512 seconds
Time After: 0.04549 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04692 seconds
Time After: 0.04829 seconds
Time Taken: 0.00137 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.04446 seconds
Time After: 0.04850 seconds
Time Taken: 0.00405 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.10279 seconds
Time After: 0.10313 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.24416 seconds
Time After: 0.24541 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.24747586250305
Time Before: 0.27749 seconds
Time After: 0.27767 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.28348 seconds
Time After: 0.28502 seconds
Time Taken: 0.00154 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=137283'
WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.31634 seconds
Time After: 0.31659 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
Page generated in 0.31534600257874 seconds with 9 queries, spending 0.008319616317749 doing MySQL queries and 0.30702638626099 doing PHP things.
