Time Before: 0.00752 seconds
Time After: 0.01016 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01025 seconds
Time After: 0.01062 seconds
Time Before: 0.01088 seconds
Time After: 0.01100 seconds
Time Before: 0.01167 seconds
Time After: 0.01413 seconds
Time Taken: 0.00246 seconds
Time Before: 0.01106 seconds
Time After: 0.01850 seconds
Time Taken: 0.00744 seconds
Time Before: 0.02220 seconds
Time After: 0.02262 seconds
Time Before: 0.02488 seconds
Time After: 0.02606 seconds
Time Taken: 0.00118 seconds
Time Before: 0.02148 seconds
Time After: 0.02628 seconds
Time Taken: 0.00480 seconds
Time Before: 0.04121 seconds
Time After: 0.04133 seconds
Time Before: 0.04916 seconds
Time After: 0.05041 seconds
End call of global.php: 0.052374124526978
Time Before: 0.05562 seconds
Time After: 0.05589 seconds
Time Before: 0.05796 seconds
Time After: 0.05940 seconds
SET lastactivity = 1776552197, location = '/forums/private.php?do=newpm&explain=1&u=137302'
Time Before: 0.07555 seconds
Time After: 0.07761 seconds
Time Taken: 0.00206 seconds
Page generated in 0.074517965316772 seconds with 9 queries, spending 0.0096943378448486 doing MySQL queries and 0.064823627471924 doing PHP things.
