Time Before: 0.01379 seconds
Time After: 0.01854 seconds
Time Taken: 0.00474 seconds
Time Before: 0.01864 seconds
Time After: 0.01918 seconds
Time Taken: 0.00054 seconds
Time Before: 0.01938 seconds
Time After: 0.01954 seconds
Time Before: 0.02037 seconds
Time After: 0.02277 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01963 seconds
Time After: 0.02735 seconds
Time Taken: 0.00772 seconds
Time Before: 0.03368 seconds
Time After: 0.03406 seconds
Time Before: 0.03654 seconds
Time After: 0.03774 seconds
Time Before: 0.03295 seconds
Time After: 0.03798 seconds
Time Taken: 0.00503 seconds
Time Before: 0.06823 seconds
Time After: 0.06844 seconds
Time Before: 0.08220 seconds
Time After: 0.08350 seconds
Time Before: 0.09175 seconds
Time After: 0.09193 seconds
Time Before: 0.09433 seconds
Time After: 0.09584 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1784883040, location = '/forums/private.php?do=newpm&explain=1&u=137347' WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.11442 seconds
Time After: 0.11468 seconds
