Time Before: 0.00164 seconds
Time After: 0.00218 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00226 seconds
Time After: 0.00284 seconds
Time Taken: 0.00058 seconds
Time Before: 0.00316 seconds
Time After: 0.00330 seconds
Time Before: 0.00404 seconds
Time After: 0.00641 seconds
Time Taken: 0.00237 seconds
Time Before: 0.00336 seconds
Time After: 0.00983 seconds
Time Taken: 0.00648 seconds
Time Before: 0.01179 seconds
Time After: 0.01215 seconds
Time Before: 0.01443 seconds
Time After: 0.01564 seconds
Time Before: 0.01119 seconds
Time After: 0.01583 seconds
Time Taken: 0.00464 seconds
Time Before: 0.02139 seconds
Time After: 0.02159 seconds
Time Before: 0.02384 seconds
Time After: 0.02507 seconds
Time Before: 0.02824 seconds
Time After: 0.02845 seconds
Time Before: 0.03053 seconds
Time After: 0.03194 seconds
UPDATE session SET lastactivity = 1784736393, location = '/forums/private.php?do=newpm&explain=1&u=13738', badlocation = 1 WHERE sessionhash = 'b910b85238c3231bdc641e11d90490dd'
Time Before: 0.04448 seconds
Time After: 0.04502 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
