Time Before: 0.00161 seconds
Time After: 0.00211 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00218 seconds
Time After: 0.00262 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00297 seconds
Time After: 0.00313 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00386 seconds
Time After: 0.00654 seconds
Time Taken: 0.00269 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00318 seconds
Time After: 0.01119 seconds
Time Taken: 0.00801 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01321 seconds
Time After: 0.01360 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01632 seconds
Time After: 0.01774 seconds
Memory Before: 2,771.539 KB
Memory After: 2,771.398 KB
Time Before: 0.01266 seconds
Time After: 0.01791 seconds
Time Taken: 0.00525 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.430 KB
Time Before: 0.02320 seconds
Time After: 0.02335 seconds
Memory Before: 3,437.555 KB
Memory After: 3,438.070 KB
Time Before: 0.02574 seconds
Time After: 0.02704 seconds
Time Taken: 0.00131 seconds
Memory Before: 3,525.352 KB
Memory After: 3,525.945 KB
Time Before: 0.03123 seconds
Time After: 0.03138 seconds
Memory Before: 4,163.250 KB
Memory After: 4,163.680 KB
Time Before: 0.03364 seconds
Time After: 0.03511 seconds
Memory Before: 4,444.789 KB
Memory After: 4,446.477 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137463' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.04930 seconds
Time After: 0.04960 seconds
Memory Before: 4,918.398 KB
Memory After: 4,918.641 KB
