Time Before: 0.03329 seconds
Time After: 0.04145 seconds
Time Taken: 0.00816 seconds
Memory Before: 532.289 KB
Memory After: 557.406 KB
Time Before: 0.04153 seconds
Time After: 0.04193 seconds
Memory Before: 557.344 KB
Memory After: 558.352 KB
Time Before: 0.04213 seconds
Time After: 0.04233 seconds
Memory Before: 558.906 KB
Memory After: 559.430 KB
Time Before: 0.04312 seconds
Time After: 0.04696 seconds
Time Taken: 0.00384 seconds
Memory Before: 562.031 KB
Memory After: 562.953 KB
Time Before: 0.04240 seconds
Time After: 0.05188 seconds
Time Taken: 0.00949 seconds
Memory Before: 558.680 KB
Memory After: 1,639.734 KB
Memory Used: 1,081.055 KB
Time Before: 0.06274 seconds
Time After: 0.06294 seconds
Memory Before: 2,134.656 KB
Memory After: 2,135.273 KB
Time Before: 0.06603 seconds
Time After: 0.06737 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,146.836 KB
Memory After: 2,146.695 KB
Time Before: 0.06199 seconds
Time After: 0.06765 seconds
Time Taken: 0.00567 seconds
Memory Before: 2,126.836 KB
Memory After: 2,260.047 KB
Memory Used: 133.211 KB
Time Before: 0.10083 seconds
Time After: 0.10097 seconds
Memory Before: 2,813.594 KB
Memory After: 2,814.109 KB
Time Before: 0.12271 seconds
Time After: 0.12400 seconds
Memory Before: 2,901.883 KB
Memory After: 2,902.477 KB
End call of global.php: 0.12637996673584
Time Before: 0.13181 seconds
Time After: 0.13195 seconds
Memory Before: 3,538.656 KB
Memory After: 3,539.086 KB
Time Before: 0.13463 seconds
Time After: 0.13606 seconds
Memory Before: 3,820.188 KB
Memory After: 3,821.875 KB
SET lastactivity = 1789037503, location = '/forums/private.php?do=newpm&explain=1&u=137513'
Time Before: 0.15292 seconds
Time After: 0.15333 seconds
Memory Before: 4,298.492 KB
Memory After: 4,298.719 KB
Page generated in 0.15185809135437 seconds with 9 queries, spending 0.009376049041748 doing MySQL queries and 0.14248204231262 doing PHP things.
