Time Before: 0.02506 seconds
Time After: 0.02898 seconds
Time Taken: 0.00392 seconds
Time Before: 0.02909 seconds
Time After: 0.02953 seconds
Time Before: 0.02979 seconds
Time After: 0.02996 seconds
Time Before: 0.03080 seconds
Time After: 0.03331 seconds
Time Taken: 0.00251 seconds
Time Before: 0.03004 seconds
Time After: 0.03742 seconds
Time Taken: 0.00738 seconds
Time Before: 0.04429 seconds
Time After: 0.04469 seconds
Time Before: 0.04739 seconds
Time After: 0.04863 seconds
Time Before: 0.04349 seconds
Time After: 0.04891 seconds
Time Taken: 0.00542 seconds
Time Before: 0.08659 seconds
Time After: 0.08675 seconds
Time Before: 0.10357 seconds
Time After: 0.10481 seconds
End call of global.php: 0.10673117637634
Time Before: 0.11257 seconds
Time After: 0.11274 seconds
Time Before: 0.11510 seconds
Time After: 0.11661 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1783017837, location = '/forums/private.php?do=newpm&explain=1&u=137520', badlocation = 1
Time Before: 0.13836 seconds
Time After: 0.13864 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.13710618019104 seconds with 9 queries, spending 0.0081098079681396 doing MySQL queries and 0.1289963722229 doing PHP things.
