Time Before: 0.01375 seconds
Time After: 0.01710 seconds
Time Taken: 0.00335 seconds
Time Before: 0.01718 seconds
Time After: 0.01763 seconds
Time Before: 0.01790 seconds
Time After: 0.01801 seconds
Time Before: 0.01880 seconds
Time After: 0.02132 seconds
Time Taken: 0.00252 seconds
Time Before: 0.01809 seconds
Time After: 0.02562 seconds
Time Taken: 0.00754 seconds
Time Before: 0.02993 seconds
Time After: 0.03034 seconds
Time Before: 0.03281 seconds
Time After: 0.03408 seconds
Time Before: 0.02927 seconds
Time After: 0.03427 seconds
Time Taken: 0.00499 seconds
Time Before: 0.05974 seconds
Time After: 0.05989 seconds
Time Before: 0.07356 seconds
Time After: 0.07528 seconds
Time Taken: 0.00172 seconds
Time Before: 0.08254 seconds
Time After: 0.08274 seconds
Time Before: 0.08565 seconds
Time After: 0.08709 seconds
UPDATE session SET lastactivity = 1785479066, location = '/forums/private.php?do=newpm&explain=1&u=137554' WHERE sessionhash = 'f787d15acff2abe23491441932164758'
Time Before: 0.10583 seconds
Time After: 0.10620 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
