Time Before: 0.02196 seconds
Time After: 0.02900 seconds
Time Taken: 0.00704 seconds
Time Before: 0.02911 seconds
Time After: 0.02951 seconds
Time Before: 0.02982 seconds
Time After: 0.02996 seconds
Time Before: 0.03086 seconds
Time After: 0.03318 seconds
Time Taken: 0.00232 seconds
Time Before: 0.03002 seconds
Time After: 0.03706 seconds
Time Before: 0.04847 seconds
Time After: 0.04897 seconds
Time Before: 0.05167 seconds
Time After: 0.05292 seconds
Time Before: 0.04777 seconds
Time After: 0.05314 seconds
Time Taken: 0.00537 seconds
Time Before: 0.08630 seconds
Time After: 0.08646 seconds
Time Before: 0.10314 seconds
Time After: 0.10447 seconds
Time Taken: 0.00133 seconds
Time Before: 0.11430 seconds
Time After: 0.11444 seconds
Time Before: 0.11720 seconds
Time After: 0.11869 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137624' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.13654 seconds
Time After: 0.13680 seconds
Memory Before: 4,911.586 KB
Memory After: 4,911.828 KB
