Time Before: 0.02471 seconds
Time After: 0.02929 seconds
Time Taken: 0.00458 seconds
Time Before: 0.02939 seconds
Time After: 0.02986 seconds
Time Before: 0.03012 seconds
Time After: 0.03025 seconds
Time Before: 0.03104 seconds
Time After: 0.03340 seconds
Time Taken: 0.00236 seconds
Time Before: 0.03032 seconds
Time After: 0.03754 seconds
Time Taken: 0.00722 seconds
Time Before: 0.04631 seconds
Time After: 0.04675 seconds
Time Before: 0.04940 seconds
Time After: 0.05069 seconds
Time Before: 0.04564 seconds
Time After: 0.05094 seconds
Time Taken: 0.00530 seconds
Time Before: 0.09511 seconds
Time After: 0.09528 seconds
Time Before: 0.11337 seconds
Time After: 0.11467 seconds
Time Before: 0.12410 seconds
Time After: 0.12428 seconds
Time Before: 0.12684 seconds
Time After: 0.12828 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137649' WHERE sessionhash = '3d710f9993f3eccc4700b01c2edbb01a'
Time Before: 0.14560 seconds
Time After: 0.14594 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
