Time Before: 0.01297 seconds
Time After: 0.01725 seconds
Time Taken: 0.00428 seconds
Time Before: 0.01732 seconds
Time After: 0.01785 seconds
Time Taken: 0.00053 seconds
Time Before: 0.01808 seconds
Time After: 0.01822 seconds
Time Before: 0.01897 seconds
Time After: 0.02362 seconds
Time Taken: 0.00465 seconds
Time Before: 0.01829 seconds
Time After: 0.02779 seconds
Time Taken: 0.00950 seconds
Time Before: 0.03301 seconds
Time After: 0.03353 seconds
Time Before: 0.03602 seconds
Time After: 0.03876 seconds
Time Taken: 0.00274 seconds
Time Before: 0.03207 seconds
Time After: 0.03903 seconds
Time Taken: 0.00696 seconds
Time Before: 0.06354 seconds
Time After: 0.06371 seconds
Time Before: 0.07383 seconds
Time After: 0.07507 seconds
Time Before: 0.08206 seconds
Time After: 0.08230 seconds
Time Before: 0.08523 seconds
Time After: 0.08719 seconds
Time Taken: 0.00197 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137711', badlocation = 1 WHERE sessionhash = '75e04c9d1feaccc7f3317da0d2511d02'
Time Before: 0.10361 seconds
Time After: 0.10388 seconds
Memory Before: 4,911.867 KB
Memory After: 4,912.094 KB
