Time Before: 0.02183 seconds
Time After: 0.03089 seconds
Time Taken: 0.00906 seconds
Time Before: 0.03099 seconds
Time After: 0.03140 seconds
Time Before: 0.03168 seconds
Time After: 0.03186 seconds
Time Before: 0.03265 seconds
Time After: 0.03606 seconds
Time Taken: 0.00340 seconds
Time Before: 0.03194 seconds
Time After: 0.04014 seconds
Time Taken: 0.00820 seconds
Time Before: 0.04744 seconds
Time After: 0.04783 seconds
Time Before: 0.05093 seconds
Time After: 0.05215 seconds
Time Before: 0.04674 seconds
Time After: 0.05236 seconds
Time Taken: 0.00563 seconds
Time Before: 0.08741 seconds
Time After: 0.08764 seconds
Time Before: 0.10778 seconds
Time After: 0.10908 seconds
Time Before: 0.12016 seconds
Time After: 0.12034 seconds
Time Before: 0.12307 seconds
Time After: 0.12450 seconds
UPDATE session SET lastactivity = 1783000098, location = '/forums/private.php?do=newpm&explain=1&u=137726' WHERE sessionhash = 'f9921609250f226198462d57df303337'
Time Before: 0.14003 seconds
Time After: 0.14030 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
