Time Before: 0.00159 seconds
Time After: 0.00214 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00221 seconds
Time After: 0.00259 seconds
Time Before: 0.00288 seconds
Time After: 0.00304 seconds
Time Before: 0.00393 seconds
Time After: 0.00670 seconds
Time Taken: 0.00277 seconds
Time Before: 0.00312 seconds
Time After: 0.01140 seconds
Time Taken: 0.00828 seconds
Time Before: 0.01320 seconds
Time After: 0.01358 seconds
Time Before: 0.01606 seconds
Time After: 0.01727 seconds
Time Before: 0.01260 seconds
Time After: 0.01745 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02228 seconds
Time After: 0.02245 seconds
Time Before: 0.02445 seconds
Time After: 0.02569 seconds
Time Before: 0.02843 seconds
Time After: 0.02858 seconds
Time Before: 0.03050 seconds
Time After: 0.03193 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137733' WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04458 seconds
Time After: 0.04486 seconds
