Time Before: 0.02256 seconds
Time After: 0.03222 seconds
Time Taken: 0.00965 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03234 seconds
Time After: 0.03287 seconds
Time Taken: 0.00054 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03311 seconds
Time After: 0.03327 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03413 seconds
Time After: 0.03719 seconds
Time Taken: 0.00306 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03334 seconds
Time After: 0.04196 seconds
Time Taken: 0.00862 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05106 seconds
Time After: 0.05128 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05375 seconds
Time After: 0.05699 seconds
Time Taken: 0.00323 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.05041 seconds
Time After: 0.05725 seconds
Time Taken: 0.00683 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.10508 seconds
Time After: 0.10524 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.59901 seconds
Time After: 0.60118 seconds
Time Taken: 0.00217 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.62685 seconds
Time After: 0.62700 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.63259 seconds
Time After: 0.63487 seconds
Time Taken: 0.00228 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1772747927, location = '/forums/private.php?do=newpm&explain=1&u=137763', badlocation = 1 WHERE sessionhash = 'c9ecef9835dff112a7666634a7a1b42a'
Time Before: 0.66339 seconds
Time After: 0.66369 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
