Time Before: 0.01363 seconds
Time After: 0.01880 seconds
Time Taken: 0.00517 seconds
Time Before: 0.01890 seconds
Time After: 0.01937 seconds
Time Before: 0.01962 seconds
Time After: 0.01976 seconds
Time Before: 0.02062 seconds
Time After: 0.02318 seconds
Time Taken: 0.00256 seconds
Time Before: 0.01981 seconds
Time After: 0.02720 seconds
Time Taken: 0.00738 seconds
Time Before: 0.03299 seconds
Time After: 0.03345 seconds
Time Before: 0.03643 seconds
Time After: 0.03767 seconds
Time Before: 0.03222 seconds
Time After: 0.03790 seconds
Time Taken: 0.00568 seconds
Time Before: 0.06306 seconds
Time After: 0.06323 seconds
Time Before: 0.07362 seconds
Time After: 0.07490 seconds
End call of global.php: 0.076992034912109
Time Before: 0.08351 seconds
Time After: 0.08368 seconds
Time Before: 0.08618 seconds
Time After: 0.08765 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=137813', badlocation = 1
Time Before: 0.10229 seconds
Time After: 0.10268 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.10134887695312 seconds with 9 queries, spending 0.0083677768707275 doing MySQL queries and 0.092981100082397 doing PHP things.
