Time Before: 0.00986 seconds
Time After: 0.01563 seconds
Time Taken: 0.00578 seconds
Time Before: 0.01573 seconds
Time After: 0.01618 seconds
Time Before: 0.01646 seconds
Time After: 0.01660 seconds
Time Before: 0.01740 seconds
Time After: 0.02057 seconds
Time Taken: 0.00317 seconds
Time Before: 0.01670 seconds
Time After: 0.02508 seconds
Time Taken: 0.00837 seconds
Time Before: 0.02954 seconds
Time After: 0.02999 seconds
Time Before: 0.03234 seconds
Time After: 0.03355 seconds
Time Before: 0.02898 seconds
Time After: 0.03383 seconds
Time Taken: 0.00485 seconds
Time Before: 0.05106 seconds
Time After: 0.05125 seconds
Time Before: 0.06204 seconds
Time After: 0.06333 seconds
Time Before: 0.07000 seconds
Time After: 0.07015 seconds
Time Before: 0.07266 seconds
Time After: 0.07409 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137834' WHERE sessionhash = '7f12e449499bf5aa31d8d04cb08a0450'
Time Before: 0.09025 seconds
Time After: 0.09057 seconds
