Time Before: 0.01759 seconds
Time After: 0.02243 seconds
Time Taken: 0.00483 seconds
Time Before: 0.02251 seconds
Time After: 0.02293 seconds
Time Before: 0.02312 seconds
Time After: 0.02323 seconds
Time Before: 0.02393 seconds
Time After: 0.02633 seconds
Time Taken: 0.00240 seconds
Time Before: 0.02330 seconds
Time After: 0.02999 seconds
Time Taken: 0.00669 seconds
Time Before: 0.03462 seconds
Time After: 0.03503 seconds
Time Before: 0.03756 seconds
Time After: 0.03879 seconds
Time Before: 0.03398 seconds
Time After: 0.03897 seconds
Time Taken: 0.00499 seconds
Time Before: 0.05593 seconds
Time After: 0.05608 seconds
Time Before: 0.06673 seconds
Time After: 0.06796 seconds
Time Before: 0.07548 seconds
Time After: 0.07566 seconds
Time Before: 0.07802 seconds
Time After: 0.07949 seconds
UPDATE session SET lastactivity = 1788871714, location = '/forums/private.php?do=newpm&explain=1&u=137868', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.09733 seconds
Time After: 0.09762 seconds
