Time Before: 0.02951 seconds
Time After: 0.03877 seconds
Time Taken: 0.00926 seconds
Time Before: 0.03885 seconds
Time After: 0.03934 seconds
Time Before: 0.03961 seconds
Time After: 0.03978 seconds
Time Before: 0.04054 seconds
Time After: 0.04284 seconds
Time Taken: 0.00230 seconds
Time Before: 0.03985 seconds
Time After: 0.04702 seconds
Time Taken: 0.00717 seconds
Time Before: 0.05684 seconds
Time After: 0.05728 seconds
Time Before: 0.06052 seconds
Time After: 0.06184 seconds
Time Taken: 0.00132 seconds
Time Before: 0.05615 seconds
Time After: 0.06205 seconds
Time Taken: 0.00591 seconds
Time Before: 0.10919 seconds
Time After: 0.10937 seconds
Time Before: 0.13066 seconds
Time After: 0.13194 seconds
End call of global.php: 0.13410115242004
Time Before: 0.14300 seconds
Time After: 0.14317 seconds
Time Before: 0.14619 seconds
Time After: 0.14764 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=137884', badlocation = 1
Time Before: 0.16650 seconds
Time After: 0.16687 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.16552209854126 seconds with 9 queries, spending 0.0081682205200195 doing MySQL queries and 0.15735387802124 doing PHP things.
