Time Before: 0.00138 seconds
Time After: 0.00189 seconds
Time Before: 0.00196 seconds
Time After: 0.00245 seconds
Time Before: 0.00264 seconds
Time After: 0.00276 seconds
Time Before: 0.00356 seconds
Time After: 0.00623 seconds
Time Taken: 0.00267 seconds
Time Before: 0.00283 seconds
Time After: 0.00956 seconds
Time Taken: 0.00673 seconds
Time Before: 0.01133 seconds
Time After: 0.01180 seconds
Time Before: 0.01521 seconds
Time After: 0.01657 seconds
Time Taken: 0.00135 seconds
Time Before: 0.01070 seconds
Time After: 0.01678 seconds
Time Taken: 0.00608 seconds
Time Before: 0.02181 seconds
Time After: 0.02193 seconds
Time Before: 0.02405 seconds
Time After: 0.02528 seconds
End call of global.php: 0.026882171630859
Time Before: 0.02833 seconds
Time After: 0.02847 seconds
Time Before: 0.03053 seconds
Time After: 0.03193 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1785294223, location = '/forums/private.php?do=newpm&explain=1&u=137885', badlocation = 1
Time Before: 0.04455 seconds
Time After: 0.04495 seconds
Page generated in 0.043652057647705 seconds with 9 queries, spending 0.0083842277526855 doing MySQL queries and 0.03526782989502 doing PHP things.
