Time Before: 0.02411 seconds
Time After: 0.02906 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02916 seconds
Time After: 0.02960 seconds
Time Before: 0.02985 seconds
Time After: 0.03003 seconds
Time Before: 0.03090 seconds
Time After: 0.03340 seconds
Time Taken: 0.00250 seconds
Time Before: 0.03011 seconds
Time After: 0.03766 seconds
Time Taken: 0.00755 seconds
Time Before: 0.04648 seconds
Time After: 0.04690 seconds
Time Before: 0.04977 seconds
Time After: 0.05302 seconds
Time Taken: 0.00325 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.04578 seconds
Time After: 0.05328 seconds
Time Taken: 0.00750 seconds
Memory After: 2,261.703 KB
Time Before: 0.11034 seconds
Time After: 0.11047 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.13310 seconds
Time After: 0.13439 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.14356 seconds
Time After: 0.14373 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.14625 seconds
Time After: 0.14768 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=137891', badlocation = 1 WHERE sessionhash = '2e9a27470c1bd6d04caedfc611bd3cf4'
Time Before: 0.16685 seconds
Time After: 0.16726 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
