Time Before: 0.00392 seconds
Time After: 0.00515 seconds
Time Before: 0.00523 seconds
Time After: 0.00563 seconds
Time Before: 0.00586 seconds
Time After: 0.00602 seconds
Time Before: 0.00695 seconds
Time After: 0.00913 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00610 seconds
Time After: 0.01454 seconds
Time Taken: 0.00844 seconds
Time Before: 0.01747 seconds
Time After: 0.01832 seconds
Time Taken: 0.00086 seconds
Time Before: 0.02210 seconds
Time After: 0.02335 seconds
Time Before: 0.01672 seconds
Time After: 0.02366 seconds
Time Taken: 0.00694 seconds
Time Before: 0.03412 seconds
Time After: 0.03427 seconds
Time Before: 0.03847 seconds
Time After: 0.04044 seconds
Time Taken: 0.00197 seconds
Time Before: 0.04349 seconds
Time After: 0.04363 seconds
Time Before: 0.04594 seconds
Time After: 0.04771 seconds
Time Taken: 0.00177 seconds
UPDATE session SET lastactivity = 1788932085, location = '/forums/private.php?do=newpm&explain=1&u=137897' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.06500 seconds
Time After: 0.06540 seconds
