Time Before: 0.01374 seconds
Time After: 0.02193 seconds
Time Taken: 0.00819 seconds
Time Before: 0.02204 seconds
Time After: 0.02257 seconds
Time Before: 0.02286 seconds
Time After: 0.02300 seconds
Time Before: 0.02385 seconds
Time After: 0.02577 seconds
Time Taken: 0.00193 seconds
Time Before: 0.02305 seconds
Time After: 0.03015 seconds
Time Taken: 0.00710 seconds
Time Before: 0.03856 seconds
Time After: 0.03901 seconds
Time Before: 0.04082 seconds
Time After: 0.04206 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03777 seconds
Time After: 0.04224 seconds
Time Taken: 0.00447 seconds
Memory After: 2,261.820 KB
Time Before: 0.06921 seconds
Time After: 0.06937 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.09254 seconds
Time After: 0.09379 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.10895 seconds
Time After: 0.10911 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.11175 seconds
Time After: 0.11318 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788904610, location = '/forums/private.php?do=newpm&explain=1&u=137898', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.13643 seconds
Time After: 0.13679 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
