Time Before: 0.02709 seconds
Time After: 0.03782 seconds
Time Taken: 0.01073 seconds
Time Before: 0.03791 seconds
Time After: 0.03833 seconds
Time Before: 0.03858 seconds
Time After: 0.03872 seconds
Time Before: 0.03959 seconds
Time After: 0.04316 seconds
Time Taken: 0.00358 seconds
Time Before: 0.03879 seconds
Time After: 0.04762 seconds
Time Taken: 0.00883 seconds
Time Before: 0.05661 seconds
Time After: 0.05705 seconds
Time Before: 0.06015 seconds
Time After: 0.06134 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.05581 seconds
Time After: 0.06158 seconds
Time Taken: 0.00576 seconds
Memory After: 2,261.820 KB
Time Before: 0.09483 seconds
Time After: 0.09496 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
REPLACE INTO datastore
	(title, data, unserialize)
VALUES
	('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"33.89,\";s:9:\"lastcheck\";i:1789051456;}', 1)
Time Before: 0.11880 seconds
Time After: 0.12008 seconds
Memory Before: 2,816.633 KB
Memory After: 2,816.883 KB
Memory Used: 0.250 KB
Time Before: 0.40519 seconds
Time After: 0.40657 seconds
Time Taken: 0.00138 seconds
Memory Before: 2,903.938 KB
Memory After: 2,904.531 KB
End call of global.php: 0.40963912010193
Time Before: 0.41650 seconds
Time After: 0.41666 seconds
Memory Before: 3,540.688 KB
Memory After: 3,541.117 KB
Time Before: 0.41972 seconds
Time After: 0.42129 seconds
Time Taken: 0.00157 seconds
Memory Before: 3,822.422 KB
Memory After: 3,824.109 KB
SET lastactivity = 1789051456, location = '/forums/private.php?do=newpm&explain=1&u=137971'
Time Before: 0.44093 seconds
Time After: 0.44117 seconds
Memory Before: 4,296.156 KB
Memory After: 4,296.383 KB
Page generated in 0.43978404998779 seconds with 10 queries, spending 0.010536193847656 doing MySQL queries and 0.42924785614014 doing PHP things.
