Time Before: 0.01419 seconds
Time After: 0.01698 seconds
Time Taken: 0.00280 seconds
Time Before: 0.01708 seconds
Time After: 0.01846 seconds
Time Taken: 0.00138 seconds
Time Before: 0.01875 seconds
Time After: 0.01899 seconds
Time Before: 0.01994 seconds
Time After: 0.02274 seconds
Time Before: 0.01907 seconds
Time After: 0.02811 seconds
Time Taken: 0.00904 seconds
Time Before: 0.03328 seconds
Time After: 0.03348 seconds
Time Before: 0.03618 seconds
Time After: 0.03753 seconds
Time Taken: 0.00135 seconds
Time Before: 0.03259 seconds
Time After: 0.03777 seconds
Time Taken: 0.00518 seconds
Time Before: 0.05856 seconds
Time After: 0.05872 seconds
Time Before: 0.06707 seconds
Time After: 0.06839 seconds
Time Taken: 0.00132 seconds
End call of global.php: 0.070566177368164
Time Before: 0.07452 seconds
Time After: 0.07469 seconds
Time Before: 0.07812 seconds
Time After: 0.07962 seconds
Time Taken: 0.00150 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=137994', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.09512 seconds
Time After: 0.09547 seconds
Page generated in 0.09407901763916 seconds with 9 queries, spending 0.009451150894165 doing MySQL queries and 0.084627866744995 doing PHP things.
