Time Before: 0.00157 seconds
Time After: 0.00222 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00233 seconds
Time After: 0.00294 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00328 seconds
Time After: 0.00347 seconds
Time Before: 0.00419 seconds
Time After: 0.00701 seconds
Time Taken: 0.00282 seconds
Time Before: 0.00354 seconds
Time After: 0.01135 seconds
Time Taken: 0.00781 seconds
Time Before: 0.01335 seconds
Time After: 0.01377 seconds
Time Before: 0.01728 seconds
Time After: 0.01879 seconds
Time Taken: 0.00151 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01268 seconds
Time After: 0.01901 seconds
Time Taken: 0.00633 seconds
Memory After: 2,261.703 KB
Time Before: 0.02435 seconds
Time After: 0.02454 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02630 seconds
Time After: 0.02766 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
End call of global.php: 0.029377222061157
Time Before: 0.03053 seconds
Time After: 0.03071 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03393 seconds
Time After: 0.03617 seconds
Time Taken: 0.00224 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=138002', badlocation = 1
Time Before: 0.04913 seconds
Time After: 0.04955 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
Page generated in 0.048177003860474 seconds with 9 queries, spending 0.0099434852600098 doing MySQL queries and 0.038233518600464 doing PHP things.
