Time Before: 0.01447 seconds
Time After: 0.01776 seconds
Time Taken: 0.00329 seconds
Time Before: 0.01783 seconds
Time After: 0.01825 seconds
Time Before: 0.01848 seconds
Time After: 0.01859 seconds
Time Before: 0.01929 seconds
Time After: 0.02206 seconds
Time Taken: 0.00277 seconds
Time Before: 0.01864 seconds
Time After: 0.02595 seconds
Time Taken: 0.00731 seconds
Time Before: 0.03224 seconds
Time After: 0.03258 seconds
Time Before: 0.03518 seconds
Time After: 0.03645 seconds
Time Before: 0.03165 seconds
Time After: 0.03666 seconds
Time Taken: 0.00500 seconds
Time Before: 0.06634 seconds
Time After: 0.06655 seconds
Time Before: 0.07965 seconds
Time After: 0.08091 seconds
Time Before: 0.09490 seconds
Time After: 0.09511 seconds
Time Before: 0.09788 seconds
Time After: 0.09937 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138059', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.11724 seconds
Time After: 0.11758 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
