Time Before: 0.01323 seconds
Time After: 0.01795 seconds
Time Taken: 0.00471 seconds
Time Before: 0.01803 seconds
Time After: 0.01919 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01943 seconds
Time After: 0.01954 seconds
Time Before: 0.02029 seconds
Time After: 0.02470 seconds
Time Taken: 0.00442 seconds
Time Before: 0.01959 seconds
Time After: 0.02913 seconds
Time Taken: 0.00954 seconds
Time Before: 0.03611 seconds
Time After: 0.03651 seconds
Time Before: 0.03947 seconds
Time After: 0.04063 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03544 seconds
Time After: 0.04085 seconds
Time Taken: 0.00541 seconds
Memory After: 2,261.820 KB
Time Before: 0.06267 seconds
Time After: 0.06280 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.07417 seconds
Time After: 0.07592 seconds
Time Taken: 0.00175 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.08275 seconds
Time After: 0.08289 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.08549 seconds
Time After: 0.08704 seconds
Time Taken: 0.00154 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788979193, location = '/forums/private.php?do=newpm&explain=1&u=138096' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.10498 seconds
Time After: 0.10562 seconds
Time Taken: 0.00065 seconds
Memory Before: 4,287.563 KB
Memory After: 4,287.781 KB
