Time Before: 0.01549 seconds
Time After: 0.02226 seconds
Time Taken: 0.00676 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02234 seconds
Time After: 0.02280 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02309 seconds
Time After: 0.02332 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02404 seconds
Time After: 0.02674 seconds
Time Taken: 0.00270 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02338 seconds
Time After: 0.03087 seconds
Time Taken: 0.00749 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03618 seconds
Time After: 0.03656 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03913 seconds
Time After: 0.04040 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.03553 seconds
Time After: 0.04061 seconds
Time Taken: 0.00508 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.06585 seconds
Time After: 0.06642 seconds
Time Taken: 0.00057 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.10223 seconds
Time After: 0.10348 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.12285 seconds
Time After: 0.12306 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.12675 seconds
Time After: 0.12825 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138108' WHERE sessionhash = '05469e5b46550d3cbf9ccd27256b5c39'
Time Before: 0.15176 seconds
Time After: 0.15203 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
