Time Before: 0.01129 seconds
Time After: 0.01468 seconds
Time Taken: 0.00339 seconds
Time Before: 0.01476 seconds
Time After: 0.01524 seconds
Time Before: 0.01550 seconds
Time After: 0.01565 seconds
Time Before: 0.01643 seconds
Time After: 0.01868 seconds
Time Taken: 0.00225 seconds
Time Before: 0.01571 seconds
Time After: 0.02267 seconds
Time Taken: 0.00696 seconds
Time Before: 0.02740 seconds
Time After: 0.02786 seconds
Time Before: 0.03047 seconds
Time After: 0.03169 seconds
Time Before: 0.02673 seconds
Time After: 0.03194 seconds
Time Taken: 0.00521 seconds
Time Before: 0.04977 seconds
Time After: 0.04991 seconds
Time Before: 0.06154 seconds
Time After: 0.06277 seconds
End call of global.php: 0.06486988067627
Time Before: 0.07022 seconds
Time After: 0.07038 seconds
Time Before: 0.07288 seconds
Time After: 0.07432 seconds
SET lastactivity = 1783148729, location = '/forums/private.php?do=newpm&explain=1&u=138140'
Time Before: 0.09342 seconds
Time After: 0.09369 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.092289924621582 seconds with 9 queries, spending 0.0077962875366211 doing MySQL queries and 0.084493637084961 doing PHP things.
