Time Before: 0.00141 seconds
Time After: 0.00190 seconds
Time Before: 0.00196 seconds
Time After: 0.00267 seconds
Time Taken: 0.00070 seconds
Time Before: 0.00293 seconds
Time After: 0.00309 seconds
Time Before: 0.00373 seconds
Time After: 0.00651 seconds
Time Taken: 0.00278 seconds
Time Before: 0.00313 seconds
Time After: 0.01060 seconds
Time Taken: 0.00747 seconds
Time Before: 0.01243 seconds
Time After: 0.01280 seconds
Time Before: 0.01422 seconds
Time After: 0.01540 seconds
Time Before: 0.01184 seconds
Time After: 0.01558 seconds
Time Taken: 0.00373 seconds
Time Before: 0.02106 seconds
Time After: 0.02120 seconds
Time Before: 0.02316 seconds
Time After: 0.02439 seconds
End call of global.php: 0.026120901107788
Time Before: 0.02736 seconds
Time After: 0.02756 seconds
Time Before: 0.02970 seconds
Time After: 0.03114 seconds
SET lastactivity = 1784868034, location = '/forums/private.php?do=newpm&explain=1&u=138162', badlocation = 1
WHERE sessionhash = 'b773d1d737f443efcc9fdfe9a9930185'
Time Before: 0.04605 seconds
Time After: 0.04644 seconds
Page generated in 0.044797897338867 seconds with 9 queries, spending 0.0086030960083008 doing MySQL queries and 0.036194801330566 doing PHP things.
