Time Before: 0.01297 seconds
Time After: 0.01708 seconds
Time Taken: 0.00411 seconds
Time Before: 0.01719 seconds
Time After: 0.01767 seconds
Time Before: 0.01789 seconds
Time After: 0.01801 seconds
Time Before: 0.01877 seconds
Time After: 0.02134 seconds
Time Taken: 0.00257 seconds
Time Before: 0.01806 seconds
Time After: 0.02518 seconds
Time Taken: 0.00711 seconds
Time Before: 0.02981 seconds
Time After: 0.03019 seconds
Time Before: 0.03261 seconds
Time After: 0.03379 seconds
Time Taken: 0.00117 seconds
Time Before: 0.02911 seconds
Time After: 0.03398 seconds
Time Taken: 0.00488 seconds
Time Before: 0.04869 seconds
Time After: 0.04884 seconds
Time Before: 0.05614 seconds
Time After: 0.05739 seconds
End call of global.php: 0.059062957763672
Time Before: 0.06298 seconds
Time After: 0.06312 seconds
Time Before: 0.06512 seconds
Time After: 0.06655 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=138167'
Time Before: 0.08038 seconds
Time After: 0.08068 seconds
Page generated in 0.079447031021118 seconds with 9 queries, spending 0.0079741477966309 doing MySQL queries and 0.071472883224487 doing PHP things.
