Time Before: 0.00699 seconds
Time After: 0.00894 seconds
Time Taken: 0.00195 seconds
Time Before: 0.00904 seconds
Time After: 0.00943 seconds
Time Before: 0.00976 seconds
Time After: 0.00989 seconds
Time Before: 0.01078 seconds
Time After: 0.01324 seconds
Time Taken: 0.00245 seconds
Time Before: 0.00997 seconds
Time After: 0.01784 seconds
Time Taken: 0.00786 seconds
Time Before: 0.02149 seconds
Time After: 0.02179 seconds
Time Before: 0.02366 seconds
Time After: 0.02480 seconds
Time Taken: 0.00114 seconds
Time Before: 0.02084 seconds
Time After: 0.02500 seconds
Time Taken: 0.00416 seconds
Time Before: 0.04032 seconds
Time After: 0.04044 seconds
Time Before: 0.04601 seconds
Time After: 0.04728 seconds
Time Before: 0.05223 seconds
Time After: 0.05235 seconds
Time Before: 0.05473 seconds
Time After: 0.05618 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=138215' WHERE sessionhash = 'a2a3453dc9101e6891c957de0b8179f5'
Time Before: 0.07066 seconds
Time After: 0.07089 seconds
