Time Before: 0.00159 seconds
Time After: 0.00224 seconds
Time Taken: 0.00065 seconds
Time Before: 0.00235 seconds
Time After: 0.00274 seconds
Time Before: 0.00302 seconds
Time After: 0.00324 seconds
Time Before: 0.00406 seconds
Time After: 0.00648 seconds
Time Taken: 0.00243 seconds
Time Before: 0.00329 seconds
Time After: 0.01060 seconds
Time Taken: 0.00731 seconds
Time Before: 0.01258 seconds
Time After: 0.01287 seconds
Time Before: 0.01460 seconds
Time After: 0.01586 seconds
Time Before: 0.01187 seconds
Time After: 0.01611 seconds
Time Taken: 0.00424 seconds
Time Before: 0.02266 seconds
Time After: 0.02285 seconds
Time Before: 0.04265 seconds
Time After: 0.04390 seconds
Time Before: 0.04710 seconds
Time After: 0.04726 seconds
Time Before: 0.04937 seconds
Time After: 0.05085 seconds
UPDATE session SET lastactivity = 1782893733, location = '/forums/private.php?do=newpm&explain=1&u=138241', badlocation = 1 WHERE sessionhash = '90b3c67278b177629fe550ebf4d83bbe'
Time Before: 0.06334 seconds
Time After: 0.06361 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
